Cisco Catalyst 2960-X connected to meraki AP MR 55 working in low power mode
Hi Guys,
We have currently using a number of Meraki MR 55 APs which are connected to the Cisco Catalyst switch, and are acting in low power mode due to not enough power. I tried putting in static power with max 30000 on the interfaces where these APs are connected but it still runs in low power mode.
If you guys have any suggestions let me know.
marce1000
 Ref : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_44_se/configuration/note/ol14988.html#wp1028613
 Seems max power capabilities are limited to 15.4W per port. You will need to use a back-end switch with   sufficient poe-power capabilities for the APs.
 M.
