Cisco Catalyst 2960-x Series Doesn't turn on
mmamed657
Good day everyone! I have a problem with my Cisco Catalyst 2960-x Series switch. It does not show any signs of life, only SYST is lit, and STAT, SPEED, STACK are blinking. What to do? How to solve this problem? I can't understand...
I hope you can help me)
Sincerely, Mamed
7 Replies 7
@mmamed657
 Did you try to power off the switch, press the mode button, power on the switch and hold the mode button for 20 seconds or until SYS led goes solid and release mode button?
Yes, I tried to do this, but unfortunately it doesn’t help. The STAT, SPEED, STACK indicators flash 3 times and go out and then flash again 3 times and this process is repeated again and again
What do you get on the console?
balaji.bandi
Connect the console cable and post complete boot logs here :
check LED means :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/hardware/installation/guide/b_c2960x_hig/b_c2960x_hig_chapter_01.html#ID277
BB
Mark Elsen
  - Attach a console , and check if any output can be seen on it after a power cycle ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
mmamed657
Thank you all very much) I found a solution, such a topic already exists, and I realized that it is useless to discuss it here.
This person in the discussion has the same thing as me with the switch
mmamed657
More precisely, the discussions had the same topic and problem as mine. That topic of discussion is called:
Switch WS-C2960X-24PS-IN Blinking Lights
There everything was decided by sending the switch to a service center to service the equipment and replace spare parts, since I myself cannot repair or replace anything on the switch, I am of course upset. And I am grateful to you for your responsiveness and full support.
Sincerely, Mamed
