Cisco Catalyst 3560 Web Interface (Express Setup) missing.
mike.armbruster
Community Member
I recently purchased a refurbished WS-C3560-24PS-S that seems to be working fine, but for some reason the Express Setup and the Web Interface are missing. I can only work with the unit by using the CLI with IOS commands via console port or telnet. If I try to use a browser to open the ip address for the switch I get the screen displayed below. If I click on Web Console it tells me "Web page not found". This also prevents me from using the Cisco Network Assistant with this device, which is where I manage all of our other Cisco switches. How can I activate or restore the Web Console, which is a great feature?
Currently using Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(25)SEB, RELEASE SOFTWARE (fc1).
Thank you!
Cisco Systems
Accessing Cisco WS-C3560-24PS "MAIN-ADDITION_BAK"
Show diagnostic log - display the diagnostic log.
Monitor the router - HTML access to the command line interface at level 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
Show tech-support - display information commonly needed by tech support.
Extended Ping - Send extended ping commands.
Web Console - Manage the Switch through the web interface.
glen.grant
  Probably not running a version of code with the web files.  Download the latest  .tar file for this device and install it .
  Seems you don't have the html folder on the flash. Please post the output of "dir /all".  You should see the directory of IOS and the html folder is in there.
HTH,
Toshi
