VLAN and OSPF Setting
anitachoi3
Level 6
Level 6
Dear Expert,
There is one network in HK and it is connected to ISP-A. The IP address block 192.168.80.0/21 was obtained. Five IP segments (VLANs) are allocated in HK with ospf 50:
192.168.80.0/24 (VLAN 80)
192.168.81.0/24 (VLAN 81)
192.168.82.0/24 (VLAN 82)
192.168.83.0/24 (VLAN 83)
192.168.87.0/24 (VLAN 87)
The similar infrastructure is installed in TW but only three IP segments (VLANs) are extend with different ospf 20 to be configured.
Detail please refer following "existing configuration" as below.
It seems that VLAN 83 and 87 would be unreachable if R1 was out of order in HK. To minimise service impact and configuration change in TW, extra modification would be carried out in HK only. Grateful if expert would comment on the "extra modification" to see whether it is practical or not.
===== existing configuration ====
! ********* R1 **********
interface FastEthernet0/0
descrip Connect to ISP-A in HK
ip address 172.16.32.1 255.255.255.252
speed 100
full-duplex
interface FastEthernet0/1
descrip Connect to R2
ip address 172.16.70.1 255.255.255.252
speed 100
full-duplex
router bgp 50
bgp log-neighbor-changes
network 192.168.80.0 mask 255.255.248.0
neighbor 172.16.32.2 remote-as 100
neighbor 172.16.32.2 version 4
neighbor 172.16.32.2 prefix-list 1 out
no auto-summary
access-list 1 permit 192.168.80.0 0.0.7.255
router ospf 50
log-adjacency-changes
network 192.168.80.0 0.0.7.255 area 0
! ********* R2 **********
descrip Connect to R1
ip address 172.16.70.2 255.255.255.252
speed 100
full-duplex
descrip connect to SW1 FE0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.80
descrip Connect to VLAN 80
encapsulation dot1Q 80
ip address 192.168.80.1 255.255.255.0
interface FastEthernet0/1.81
descrip Connect to VLAN 81
encapsulation dot1Q 81
ip address 192.168.81.1 255.255.255.0
interface FastEthernet0/1.82
descrip Connect to VLAN 82
encapsulation dot1Q 82
ip address 192.168.82.1 255.255.255.0
standby 82 ip 192.168.82.10
standby 82 priority 75
interface FastEthernet0/1.83
descrip Connect to VLAN 83
encapsulation dot1Q 83
ip address 192.168.83.1 255.255.255.0
interface FastEthernet0/1.87
descrip Connect to VLAN 87
encapsulation dot1Q 87
ip address 192.168.87.1 255.255.255.0
router ospf 50
ip route 0.0.0.0 0.0.0.0 172.16.70.1
! ********* SW1 **********
descri connect to R1 FE0/1
switchport mode trunk
no ip address
interface FastEthernet0/2
switchport access VLAN 80
switchport mode access
no ip address
interface FastEthernet0/3
switchport access VLAN 81
no ip address
interface FastEthernet0/4
switchport access VLAN 82
no ip address
interface FastEthernet0/5
switchport access VLAN 83
no ip address
interface FastEthernet0/6
switchport access VLAN 87
no ip address
interface FastEthernet0/24
descrip connect to WAN circuit 20M
switchport trunk allowed VLAN 80,81,82
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 192.168.80.254 255.255.255.0
no ip route-cache
ip default-gateway 192.168.80.1
no ip http server
! ********* R11 **********
descrip Connect to ISP-A in TW
ip address 172.16.64.1 255.255.255.252
speed 100
full-duplex
descrip Connect to R12
ip address 172.16.90.1 255.255.255.252
speed 100
full-duplex
router bgp 20
neighbor 172.16.64.2 remote-as 100
neighbor 172.16.64.2 version 4
neighbor 172.16.64.2 prefix-list 1 out
no auto-summary
router ospf 20
! ********* R12 **********
descrip Connect to R11
ip address 172.16.90.2 255.255.255.252
speed 100
full-duplex
descrip connect to SW11 FE0/1
no ip address
duplex auto
speed auto
ip address 192.168.80.2 255.255.255.0
ip address 192.168.81.2 255.255.255.0
ip address 192.168.82.2 255.255.255.0
standby 82 priority 150
router ospf 20
ip route 0.0.0.0 0.0.0.0 172.16.90.1
! ********* SW11 **********
descri connect to R11 FE0/1
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 192.168.80.253 255.255.255.0
no ip route-cache
ip default-gateway 192.168.80.2
no ip http server
====== end of existing config =====
===== extra modification =====
! ********* R2 ***********
router ospf 50
router ospf 20
network 192.168.80.0 0.0.0.255 area 0
! ******** SW1 ******
switchport trunk allowed VLAN 80,81,82,83,87
no ip address
! ******** SW11 ******
no ip address
====== end of extra modification ======
Fabrizio Pedracini
according to your diagram you want to have OSPF between R11 and R12 and also between R1 and R2.
You'd need to activate ospf on the interfaces connecting those routers.
i.e on R1/R2:
R1
router ospf 50
network 172.16.70.1 0.0.0.0 area 0
R2
router ospf 50
network 172.16.70.2 0.0.0.0 area 0
similar thing between R11/R12.
hope this helps,
Fabrizio
Hi Fabrizio,
After implement two OSPF instances in R2, it should pass the routes (vlan 87) from ospf 50 to ospf 20 via the VLAN 80. In other words, R12 can find the network of 192.168.87.0/24 via VLAN 80. Is it correct?
It is the main purpose why the extra ospf 20 to be created on R2.
However, one engineer suggests to perform the re-distribution from ospf 50 to ospf 20. is it the possible solution? pls advice.
rdgs
if you want to make R2 and R12 ospf neighbors on vlan 80 you don't need to create an additional ospf process on R2. Simply insert the network command under the existing "router ospf 50". Ospf process is locally significant on a router and you don't need to match the process number on 2 routers to form a neighborship.
hope this helps,
Fabrizio
