Cisco Catalyst 3650 Stack Module
pritamjitbiswas
Hi, I have 2 cisco 3650 24ts-s switch i wanted create a stack can any one please tell me the part number on the stack module and Part number on he cable .
2 Accepted Solutions
Reza Sharifi
These switches support stacking and can stack with each other or the existing 3650 switches using the same Cisco StackWise-160 technology. The 3650 mini and 3650 use the same software and thus can be deployed and managed using the same policies, configuration, and so on as the existing 3650 switches. Some use cases for the 3650 mini are the following:
The part number for stack module is:
C3650-STACK-KIT=
and for the cable:
STACK-T2-50CM=
STACK-T2-1M=
See datasheet for more info:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/data_sheet-c78-729449.html
As I remember you will require a total of 4 modules and 2 cables.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
7 Replies 7
Reza Sharifi
C3650-STACK-KIT=
and for the cable:
STACK-T2-50CM=
STACK-T2-1M=
thanx for your reply is this module and cable supported in Cisco 3650 24TS-S switch ?
Yes, they are. The switch should already have the stacking module installed. So, you just need the cable.
no sir the switch dose not have module that is why we need to perches the module and cable son could you please confirm me the module part number and cable part number.
thanx for your help
Yes, that the correct part number for the module and the cable
As you know we need to create stack between 2 switch so what is number of module and cable we need to parches ?
Deepak Kumar,
