Cisco Catalyst 4500 NetFlow Services Card
cisco_designer
Gentlemen,
I have a core switch (WS-C4507R) with these specifications:
1-IOS: Version 12.1(12c)EW1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
2-Modules Details
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor (active) WS-X4515 JAB07070xxx
3 48 10/100BaseTX (RJ45) WS-X4148-RJ JAE07060xxx
4 6 1000BaseX (GBIC) WS-X4306-GB JAE07050xxx
5 6 1000BaseX (GBIC) WS-X4306-GB JAE07092xxx
3-Supervisor Engine IV (WS-X4515)
And looking to install Netflow services add-on module, so is this module is suitable "WS-F4531(=)" and comply with these specifications?if yes how much it will be ?
amit-singh
Level 8
Level 8
Hi Friend,
First of all the IOS you are running doesnot support WS-F4531, the netflow services card.Cisco recommeded IOS version for this module is 12.2(25)EWA6.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_5184.htm#wp16938
So you have to upgrade your IOS on the switch. Another point here is that you need an application as well for the netflow statistics to be collected. Please look for that as well.
Its around $3000
HTH, Please rate if it does.
-amit singh
Hi Amit,
Based on the Data Sheet for the SUP-IV it is required to be 12.1(13)EW
From the DATA SHEET: Supervisor IV with NetFlow Services Card: Cisco IOS Software Release 12.1(13)EW or later.
On the other hand, you mentioned about the software to do a statistics so can you recommend on this software name in order to quote it.
Thank you really I appreciated.
Best Regards,
Rami
Hi dear,
regarding the software you can select this one:
Cisco CNS NetFlow Collection Engine Version 5.0
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1964/products_data_sheet09186a00801e4ebb.html
