Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Catalyst 4500 Supervisor Engine 7-E
j.konrad
Frequent Visitor
Frequent Visitor
does anybody know if there is a support for vrf-aware NAT on this supervisor?
(couldn“t find useful information anywhere)
2 Accepted Solutions
VRF aware NAT is not supported on Sup 7E, I am doubtful that it will support simple NAT. No NAT configuration was supported when this supervisor came into market & I don't see a release on CCO which supports it at present.
HTH,
Amit Aneja
Glad, that I could help. I was just discussing this with one of my co-workers in 4500 group. He mentioned that NAT is definately on radar for 4500, but not sure of the timeline.
If you don't have any further questions, please mark the question as "answered".
SunilKhanna
Level 5
Level 5
Check the Cisco Feature Navigator
Regards, Sunil Khanna
HTH,
Amit Aneja
Amit, I couldn“t find any simpe NAT support either.
And, my fault, first of all I wasnĀ“t even aware that I have to look under IOS XE to find the SUP 7-E under the feature navigator šŸ˜‰
Thanks everyone!
