Cisco Catalyst 4503 switch
boneysia_vicki
I have a doubt on Cisco Catalyst 4503.The slot 1 of the chasiss i have slot in with a supervisor engine II that integrate with IOS. If let say supervisor enigne II suddenly down, can i just replace with another supervisor engine II,does i need to re-do the configuration?does the chasiss keep the previous config file?
i do think for the 4507,but it is too expensive.
Thanks ^^
2 Accepted Solutions
Hi Friend,
You can take the backup on your tftp server.
Ankur
You can keep the config file on your PC or any other media like USB Drive/external hard Drive and then use the TFP to put it back on the supervisor engine when you want.
-amit singh
5 Replies 5
ankbhasi
Hi Friend,
The configuration is always stored in supervisor and not the chassis. So if you replace the supervisor with a new one it will be having no configuration and just a default one.
It is recommended to always keep the backup of latest configuration so that in any emergency when you replace the supervisor with new one you can just load the configuration back to the new supervisor.
Ankur
*Pls rate all helpull post
Where the backup configuration i should store?
Hi Friend,
Ankur
THANKSSS^^
-amit singh
