Cisco Catalyst 4507R+E with WS-X4748 blade, ports not working
lee.thomas
I have a Cisco Catalyst 4507R+E  (with Sup7-E) and two blades; one WS-X4748-RJ45V+E and one WS-X4648-RJ45-E.
When I connect a device to a port on the WS-X4748-RJ45V+E blade the port will not come up, show interface shows the status as "notconnect". When I connect the same device to the WS-X4648-RJ45-E blade the interface comes up.
The WS-X4748-RJ45V+E blade seems to have initialised okay, it appears in the output of "show module" as OK.
I get exactly the same effect on a second, identically configured Catalyst 4507R+E.
The software version is IOS XE 3.1.0SG, which according to the release notes supports the WS-X4748-RJ45V+E blade.
Has anybody else seen anything like this?
aarondailey
We have a customer experiencing this same issue with the WS-X4748-RJ45V+E modules (WS-X45-SUP7-E Supe).  Was there anyone else having this problem?  Was there any bugID or resolution to this?
Problem:  With these new modules, access switchports are not recognized by the endpoint unless the module is logically or physically re-seated.
Please advise!
jbrotschul
Guys,
Looks like this is an IOS bug...  We ran into it as well, so will be looking to upgrade our code...
Resolved Caveats for Cisco IOS XE Release 3.2.2SG
This section lists the resolved caveats for Cisco IOS XE Release 3.2.2SG:
• One or more line cards (WS-X46xx and WS-X47xx series) stop responding to interface changes when near-simultaneous link events (if timed correctly) occur on the same linecard.
Only line cards in the WS-X46xx series and the WS-X47xx series are affected. Interfaces that are already linked-up are not affected.
Workaround: Eliminate link flap. If the problem exists, do one of the following:
– Reload the linecard module with the hw-module module n reset command.
– For dual supervisor engines, perform a switchover. CSCts67025
-Jeff
I have 2 Core switches, single SUP on each.
Line cards #1 and #2 randomly stop forwarding packets, only solution is to reload the switch ( hw-module reset does not work ). I have cat4500e-universalk9.SPA.03.05.00.E.152-1.E.bin and the sympton looks the same as the described one,
although the code is newer than 3.2.2SG.
Now we are downgrading to cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin to check if that solves the issue,
otherwise we´ll try removing/re-inserting the modules, and if issue persists, most probably RMA the Core1.
We´ve sent a show tech to Cisco support while the issue was happening.
Current modules on the Core switches.
Mod Ports Card Type                              Model              Serial No.
1    48  10/100/1000BaseT EEE (RJ45)            WS-X4748-RJ45-E    CAT1627L48B
2    48  10/100/1000BaseT EEE (RJ45)            WS-X4748-RJ45-E    CAT1629L0ZY
3     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1629L1PD
5    12  1000BaseX (SFP)                        WS-X4612-SFP-E     JAE163007EO
M MAC addresses                    Hw  Fw           Sw               Status
1 30f7.0d57.80c0 to 30f7.0d57.80ef 1.1                               Ok
2 30f7.0dac.fd40 to 30f7.0dac.fd6f 1.1                               Ok
3 30f7.0dca.6c00 to 30f7.0dca.6c03 2.1 15.0(1r)SG10 03.05.00.E       Ok
5 a493.4c44.13e8 to a493.4c44.13f3 1.1                               Ok
Mod  Redundancy role     Operating mode      Redundancy status
3   Active Supervisor   SSO                 Active
  there appears to be a bug problem open but no fix as of yet.
CSCuc34376
Randomly some ports go down/down state on WS-X4748-RJ45V+E linecard
CSCuc34376
Symptom:
On linecard  WS-X4748-RJ45V+E randomly some ports are going down/down state. Reseat  of the card helps for some time but issue comes back again.
IP Phones which are connected to the ports experiencing the failure cannot boot properly.
Conditions:
None defined yet.
Workaround:
Reseat of the linecard. Recabling port to another one.
Customer Visible
