Cisco Catalyst 6506E VSS Stack issue
john
Level 2
Level 2
Hello All,
can you advise what the issue on this coreswitch. Show tech logs are inconsistent.
I cannot determine if there is a faulty switch module. Currently Switch 1 is standby (previously active) and Switch 2 is Active (previously standby)
------------------ show module switch all ------------------
Switch Number:     1   Role:  Virtual Switch Standby
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL100000
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL100000
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL00000
  4   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL00000
  5    5  Supervisor Engine 720 10GE (Other)     VS-S720-10G        SAL00000
  6    3  ASA Service Module                     WS-SVC-ASA-SM1     SAL00000
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  c89c.1dd7.5dac to c89c.1dd7.5ddb   4.1   12.2(18r)S1  12.2(33)SXJ1 Other
  2  c89c.1de3.5e28 to c89c.1de3.5e57   4.1   12.2(18r)S1  12.2(33)SXJ1 Other
  3  442b.0381.eaa8 to 442b.0381.ead7   4.2   12.2(18r)S1  12.2(33)SXJ1 Other
  4  e05f.b974.a6e0 to e05f.b974.a6ef   1.0   12.2(18r)S1  12.2(33)SXJ1 Other
  5  0025.453a.2f74 to 0025.453a.2f7b   4.0   8.5(4)       12.2(33)SXJ1 Other
  6  e8b7.4828.f9d0 to e8b7.4828.f9df   1.0   12.2(50r)SYL 12.2(33)SXJ1 Other
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL150000  4.1    Other
2  Centralized Forwarding Card WS-F6700-CFC       SAL100009  4.1    Other
  3  Centralized Forwarding Card WS-F6700-CFC       SA000000 YR  4.1    Other
  4  Distributed Forwarding Card WS-F6700-DFC3CXL   SAL1529KBP8  1.7    Other
  5  Policy Feature Card 3       VS-F6K-PFC3CXL     SAL100000  1.2    Other
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL00000  5.1    Other
6/0 ASA Application Processor   SVC-APP-PROC-1     SAL00000  1.0    Ok
Base PID:
Mod Model                 Serial No.
  6 WS-SVC-APP-HW-1       SAL1OOOO
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
  6  Pass
6/0 Pass
Switch Number:     2   Role:   Virtual Switch Active
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1XXX
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAZZZ
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SALXXX
  4   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL151XXX
  5    5  Supervisor Engine 720 10GE (Other)     VS-S720-10G        SAL152XXX
  6    3  ASA Service Module                     WS-SVC-ASA-SM1     SAL15XXX
  1  ccef.48bf.bd90 to ccef.48bf.bdbf   4.1   12.2(18r)S1  12.2(33)SXJ1 PwrDown
  2  0007.7d4a.028c to 0007.7d4a.02bb   4.1   12.2(18r)S1  12.2(33)SXJ1 PwrDown
  3  30e4.dbef.d668 to 30e4.dbef.d697   4.1   12.2(18r)S1  12.2(33)SXJ1 PwrDown
  4  e05f.b974.82e8 to e05f.b974.82f7   1.0   12.2(18r)S1  12.2(33)SXJ1 PwrDown
  5  0025.453a.2f84 to 0025.453a.2f8b   4.0   8.5(4)       12.2(33)SXJ1 PwrDown
  6  e8b7.4828.fb30 to e8b7.4828.fb3f   1.0   12.2(50r)SYL 12.2(33)SXJ1 PwrDown
  1  Centralized Forwarding Card WS-F6700-CFC       KXXXXXS2CZ  4.1    PwrDown
  2  Centralized Forwarding Card WS-F6700-CFC       KXXXXK99C  4.1    PwrDown
  3  Centralized Forwarding Card WS-F6700-CFC       KXXXXX5NQU  4.1    PwrDown
  4  Distributed Forwarding Card WS-F6700-DFC3CXL   KXXXXKBPW  1.7    PwrDown
  5  Policy Feature Card 3       VS-F6K-PFC3CXL     KZXXXK3C0  1.2    PwrDown
  5  MSFC3 Daughterboard         VS-F6K-MSFC3     AXXXGWMR  5.1    PwrDown
6/0 ASA Application Processor   SVC-APP-PROC-1     XSKLW3  1.0    Ok
Base PID:
  6 WS-SVC-APP-HW-1       XXXNY4
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
  6  Pass
6/0 Pass
------------------ show power switch all ------------------
Switch Number: 1
system power redundancy mode = redundant
system power total =     2771.16 Watts (65.98 Amps @ 42V)
system power used =      2338.56 Watts (55.68 Amps @ 42V)
system power available =  432.60 Watts (10.30 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-3000W       2771.16 65.98  OK     OK     on
2    WS-CAC-3000W       2771.16 65.98  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6506-E-FAN      140.70  3.35  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
2    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
3    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
4    WS-X6716-10GE       487.20 11.60   487.20 11.60  on    on
5    unknown             363.30  8.65   363.30  8.65  on    on
6    WS-SVC-ASA-SM1      370.86  8.83   370.86  8.83  on    on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   7266.00 Watts (173.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =              2338.56 Watts (55.68 Amps @ 42V)
system auxiliary power used =            0 Watt
Switch Number: 2
system power redundancy operationally = non-redundant
system power used =      2296.56 Watts (54.68 Amps @ 42V)
system power available =  474.60 Watts (11.30 Amps @ 42V)
1    WS-CAC-3000W       2771.16 65.98  -      -      unk
2    WS-CAC-3000W       2771.16 65.98  -      -      unk
                        Pwr-Allocated  Oper
1    WS-C6506-E-FAN       98.70  2.35  OK
1    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    unknown
2    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    unknown
3    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    unknown
4    WS-X6716-10GE       487.20 11.60   487.20 11.60  on    unknown
5    VS-S720-10G         363.30  8.65   363.30  8.65  on    unknown
6    WS-SVC-ASA-SM1      370.86  8.83   370.86  8.83  on    unknown
Switch 1 Module 5: Supervisor-Other  SerialNo : XXN9N
  Overall Diagnostic Result for Switch 1 Module 5 : PASS
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
Switch 2 Module 5: Supervisor Engine 720 10GE (Hot)  SerialNo : XXXNBL
  Overall Diagnostic Result for Switch 2 Module 5 : PASS
John
Leo Laohoo
I want to see the output to the command "sh logs". There's got to be some log entries why the line cards are powered down.
john
Level 2
Level 2
What exact logs you are referring to? the outputs i have shared are the show tech outputs.
Post the output to the command "sh logs" because it will state WHY the line cards are powered off.
