Cisco Catalyst 9300 Web GUI - https not working
roger perkin
Level 5
Level 5
I have setup a stack of 3 x Cisco Catalyst 9300's
Switches are operational and fully manged via SSH
I was going to look at the GUI so enabled
ip http secure-server
however when I connect to https://<switch ip>/webui it fails
This Site cannot provide a secure connection
<switch ip> uses and unsupported protocol.
This is the same for Chrome, Firefox and IE
Disabled secure-server and was able to access the switch via http, but now http://<switch ip>/webui is redirecting me to https:// then failing?
Any ideas anyone?
5 Replies 5
balaji.bandi
can you provide show version and make sure you configured below config and also username and password.
ip http server
ip http authentication local
EDIT :
reference guide with options :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-11/configuration_guide/sec/b_1611_sec_9300_cg/configuring_secure_socket_layer_http.html
BB
Mark Malone
you could check this thread below ,this was looked at in previous thread someone eventually got an update off Cisco the doc was wrong ,  after trying everything from changing tls settings, browsers etc
https://community.cisco.com/t5/switching/webui-question/td-p/3704205
Thanks for this, however my situation is the switches are up and running and being managed by SSH
If I disable secure server I can manage via http for a bit
kirank10
Level 3
Level 3
hi
i am facing same issue but http is  also not working
@balaji.bandi command that you gave sir , i had configured that too but still its not working
explain more what is not working to understand the issue correctly
BB
