Cisco Catalyst 9600 - Factory Reset
TULLYMCFARLAND
Hi all,
I have locked myself out of the switch, more specifically, I can't enable.
Every method of password recovery I have tried has failed.
I do not know how to factory reset my two stackwise-enabled switches.
I need a password recovery procedure that works with a CISCO CATALYST 9600 series switch.
If not, then...
I need to be able to reset this device WITHOUT USING ANY CLI (except ROMMON).
I have a micro-USB cable *ONLY*, I do NOT have a console cable.
Please do not mention a "Mode Button"; the Cisco 9600 doesn't have one.
Thank you for your help.
V/R
Tully
8 Replies 8
Leo Laohoo
Are you able to break the VSS?
Can you boot one of the cards into ROMMON?
Yes I am able to log into ROMMON by ctrl^c during bootup. However when the rommon1> appears the device freezes.
Does this occur to both supervisor cards?
Not entirely sure. I have not tried the 2nd chassis yet
Okay disregard, I'm able to get the device into ROMMON mode when I shorten the length of the USB cable (for some reason).
What is the next step?
I'm fine with either a password recovery option OR a total factory reset.
Yes they are stacked; there's two switches. They are both set up such that the first 2 blades are 48-port SFP blades and the third blade is the supervisory module (from top to bottom). The remaining are blank/empty/placeholder blades (whatever they're called).
Switch#copy startup-config running-config
% Copy to running-config failed because configuration changes are locked
It looks like the changes were unlocked when the VSS switch 2 re-synched with the switch I was logged into (Switch 1).
Alright I have created a new username and password with privilege level 15. I have created enable secret with the same exact password. I hope this works...
