Cisco Catalyst C1300-24XT
Joakimwork
I would like to know if Cisco Catalyst C1300-24XT is capable of 1 GbE and not only 10 GbE?
11 Replies 11
It does not seem to have any 1G port with the exception for the management port.
Cisco Catalyst 1300 Series Switches Data Sheet - Cisco
The 4 SFP+ ports should support 1/10g.
Joakimwork
Thank’s for the reply, my question is for the reason that I have to replace
my older SG/SX350 switches with newer models and SG/SX350 has no
problem with 1GbE on 10GbE ports, but what about C1300-24XT?
You're welcome. Why not to consider the 9200 series?
Cisco Catalyst 9200 Series Switches Data Sheet - Cisco
amikat
According to the Admin Guide:
"Copper Ports—Regular, not Combo, support the following values: 10M, 100M, 1000M, 2500M (type: Copper) and 10G."
Please see the speed setting as per beneath:
https://www.cisco.com/c/en/us/td/docs/switches/campus-lan-switches-access/Catalyst-1200-and-1300-Switches/cli/C1300-cli/ethernet-configuration-commands.html#wp3067314301
Best regards,
Antonin
That all the possible speed settings the CLI may support but not all Ethernet ports support all those settings.
kmccormick
According the admin guide, the 10G interface negotiates 10G, 5G, 2.5G, and 1G. Would be nice if someone from Cisco can confirm.
https://www.cisco.com/c/en/us/td/docs/switches/campus-lan-switches-access/Catalyst-1200-and-1300-Switches/cli/C1300-cli/ethernet-configuration-commands.html#wp3100158242
M02@rt37
Hello @Joakimwork
Regarding the matrix compatibility, it seems that SFPs 1G (fiber and copper) are supported. You should also verify the minimum IOS version of your platform in order to support these SFP.
https://tmgmatrix.cisco.com/?npid=6709
Best regards
The question is about auto negotiation speed options on the 10G copper ports, not the SFP ports.
Mmm OK @kmccormick
Thanks.
Best regards
Here is what the CLI guide shows. In the example the for te1/0/1the speeds advertised for 10G copper ports are 10G, 5G, 2.5G, and 1G. We just want clarification if that is true because the datasheet just list the ports at 10G. Not specifying multi-gig or the other compatible speeds is confusing. If the 1300 XT switches do support those 10G, 5G, 2.5G, and 1G on the copper ports we would be more interested in them.
Screenshot 2025-03-12 at 16-50-51 Cisco Catalyst 1300 Switches Series CLI Guide - Ethernet Configuration Commands Cisco Catalyst 1300 Series Switches - Cisco.png
