cisco catalyst clustering
frede_frede
Level 2
Level 2
Its possible to access a cluster member with ssh? rcommand use telnet and I want to remove telnet from the network
Fred
6 Replies 6
frede_frede
Level 2
Level 2
No one with this problem?
Fred
Hi Fred,
You cannot access the members directly.
Once you have logged into the cluster master switch, issue the command 'rcommand' followed by the cluster members switch number:
rcommand 3
You can confirm the cluster members with:
show cluster members
cheers,
Seb.
Hi Seb,
Yes you are right, but the rcommand use telnet, it's possible to access the members with another command that uses ssh?
Cheers,
Fred
Hi Seb,
thanks anyway
Cheers,
Fred
Once the members of the cluster have been added you can connect using ssh.
ssh cluster-member-ip-address
You can show the cluster memeber ip address by the following command.
show access-lists
Youcef
