Cisco Catalyst Switch with non-Cisco GLCs Compatibility
alshahiry
Dears,
I have and issues of using non Cisco GLCs when it attached to SFP ports as I get an error massage and ports went to shutdown status, advise how I can resolve that?
2 Accepted Solutions
Peter Paluch
In the global configuration mode, try using the following command:
service unsupported-transceiver
This command has to be fully entered from the keyboard as it is a hidden command that does not appear in interactive help and is not subject to autocompletion.
Best regards,
Peter
Reza Sharifi
what type of switch is this?
also,
sh interfaces transceiver
or
sh interfaces transceiver pro
may provide you more to see if the transceiver is supported.
Peter Paluch
Best regards,
Peter
Reza Sharifi
also,
or
The Cisco Catalyst PN WS-C3750X-12S-S and it mentioned not supported using above commands
