Network data flow not going out
ilse.v.rooyen
Community Member
Hi, I am relly new to Cisco and having a hard time with my Cisco 2800 series.
I have two sites connected with each other SiteA and  SiteB (Using the same Cisco 2800). Now site A can connect to site B on  the cisco and the internal network, but site B can only see the cisco  and not the internal network of site A. So all the traffic is coming in  to site B but can't break out of site B.
I have tried everything I can think of but again my knowledge of Cisco is not good at all.
If anyone can help me on this it will be much appreciated.
Ilse,
Yes, cisco routers configuration looks ok :). Even without much experience.
You can simply check it by pinging from any host on SiteB to any IP address of SiteA router. If the ping succeeds then your current configuration is ok.
Best regards,
Abzal
11 Replies 11
Peter Paluch
There are lots of reasons why site B can not reach site A so any suggestions at this point would be shooting in the dark. Can you post a sanitized version of your running-config, plus the output of the show ip route and a traceroute from site B to site A showing that the packets get lost past a certain point? This will help us narrow down the list of possible causes.
Thank you!
Best regards,
Peter
Ok here we go hope i have everything you need.
SITE B traceroute
Tracing route to 192.168.80.2 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  192.168.81.1
  2     1 ms    <1 ms    <1 ms  10.10.81.2
  3    32 ms    32 ms    32 ms  10.11.81.1
  4    33 ms    33 ms    33 ms  10.10.80.1
  5     *        *     ^C
SITE B show ip route
SITEB#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
S    192.168.80.0/24 [1/0] via 10.11.81.1
     10.0.0.0/30 is subnetted,
S       10.10.80.0 [1/0] via 10.11.81.1
S       10.0.80.0 [1/0] via 10.11.81.1
S       10.11.80.0 [1/0] via 10.11.81.1
C       10.10.81.0 is directly connected, FastEthernet0/0
S       10.0.81.0 [1/0] via 10.10.81.1
C       10.11.81.0 is directly connected, Serial0/1/0
S    192.168.81.0/24 [1/0] via 10.10.81.1
SITE B Running config
Current configuration : 1466 bytes
version 12.4
hostname SITEB
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$vAcJ$9r5nU4DFJ5A5xuj1aNnBu/
no aaa new-model
ip cef
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.10.81.2 255.255.255.252
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/1
bandwidth 1024
ip address 192.168.100.1 255.255.255.0
ip route-cache flow
shutdown
duplex auto
speed auto
interface Serial0/1/0
ip address 10.11.81.2 255.255.255.252
no ip classless
no ip forward-protocol nd
ip route 10.0.80.0 255.255.255.252 10.11.81.1
ip route 10.0.19.0 255.255.255.252 10.10.81.1
ip route 10.10.80.0 255.255.255.252 10.11.81.1
ip route 10.11.81.0 255.255.255.252 10.11.81.1
ip route 192.168.80.0 255.255.255.0 10.11.81.1
ip route 192.168.81.0 255.255.255.0 10.10.81.1
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
Site A running config
Current configuration : 1682 bytes
version 12.4
hostname SITEA
boot-start-marker
boot-end-marker
enable secret 5 $1$m8le$8OXQJcBOwknTShlY/1O3T/
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
voice-card 0
no dspfarm
archive
log config
  hidekeys
ip address 10.10.80.2 255.255.255.252
duplex auto
speed auto
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
ip address 10.11.81.1 255.255.255.252
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip route 10.0.80.0 255.255.255.252 10.10.80.1
ip route 10.0.81.0 255.255.255.252 10.11.81.2
ip route 10.10.81.0 255.255.255.0 10.11.81.2
ip route 192.168.80.0 255.255.255.0 10.10.80.1
ip route 192.168.81.0 255.255.255.0 10.11.19.1
ip http server
no ip http secure-server
control-plane
If I understood you correctly you network might look like this:
192.168.81.0/24                                                              192.168.80.0/24
    Router <----------> SiteB <--------> SiteA <--------> Router
Because SiteA router does not have correct return route information about 192.168.81.0/24 so your traceroute to subnets on SiteA fails.
Try to change this static route on SiteA:
no ip route 192.168.81.0 255.255.255.0 10.11.19.1
I think it should be like this on SiteA:
ip route 192.168.81.0 255.255.255.0 10.11.81.2
What device does have IP 10.11.19.1?
Also if my simple diagram is correct, check static routes on router behind SiteA. Because it might has a static routes too. It should be pointing to SiteA IPs 10.10.80.2.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Hi, sorry that is a typo on my side. The 192.168.81.0 255.255.255.0 10.11.81.2 IP is the correct one that i do have in the route's on siteA
Ok I see. Then you need to check static routes on router(L3 switch) behind SiteA router. Can you show configuration on that router?
Is there any firewall or ACL configured on that router?
Best regards,
Abzal
Behind the Cisco on site A I have a Fortigate that handels the traffic befor it goes to the internal network....
SiteA Internal network(192.168.80/24)
               | 192.168.80.1
          Fortigate
               | 10.10.80.1
               |10.10.80.2
Site A  Cisco
               |10.11.81.1
               |10.11.81.2
SiteB  Cisco
               |10.10.81.2
Now it's better to understand. So as I said you need to check configuration on Fortigate. It is a firewall as I understood. It might be blocking traffic from SiteB subnets or static routes back to SiteB subnets configured incorrectly. I don't know much about Fortigate so I can't help you with it. But the reason of your problem definitely on Fortigate.
Best regards,
Abzal
Thank you very much, so you are sure that all the configs on both sides are correct as it should be?
(Sorry i'm just making sure because i have no experiance on cisco so I can't see if im correct on the configs)
Will have a look on the Fortigate.
Thank you again for your troubles.
Best regards,
Abzal
Hi just an update it was the Fortigate, some how it did not translate the 10.10.81.0/255.255.255.252 and 10.11.81.0/255.255.255.252 IP's into the network so it did not recognize the internal IP of site B.
Thank you so much im over the moon!!
You're welcome! I'm glad that it helped you!
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
