Cisco Catos 4506 switch module faulty issue
Suresh Babu
Hi ,
I have found one error in my Cisco 4506 output of show module
Mod Slot Ports Module-Type               Model               Sub Status
1   1    2     1000BaseX Supervisor      WS-X4013            no  ok
2   2    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  ok
3   3    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  faulty
4   4    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  ok
5   5    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  ok
6   6    48    10/100BaseTx Ethernet     WS-X4148-RJ         no  ok
Can any on help on this... pls.....
Suresh
glen.grant
  Physically pull the card out and reseat the board if the error returns  a RMA is needed.
6 Replies 6
sumeet kumar
it may be hardware problem, You can remove that module and see, if any burnt.
you can remove and insert again may help you.
Hi Sumeet,
Thanks for the reply....
I have checked the status of the module physically shows is green and all ports in the module are working fine.
Only thing in show module output it shows faulty
I can notice in show ports output one of the port shows faulty . Please find below 3/7 port shows faulty and rest all are fine and connected working fine. Help me out
3/1                     connected  41         normal a-full a-100 10/100BaseTX
3/2                     notconnect 41         normal   auto  auto 10/100BaseTX
3/3                     notconnect 41         normal   auto  auto 10/100BaseTX
3/4                     notconnect 41         normal   auto  auto 10/100BaseTX
3/5                     notconnect 41         normal   auto  auto 10/100BaseTX
3/6                     notconnect 41         normal   auto  auto 10/100BaseTX
3/7                     faulty     41         normal   auto  auto 10/100BaseTX
3/8                     notconnect 41         normal   auto  auto 10/100BaseTX
3/9                     connected  41         normal a-full a-100 10/100BaseTX
3/10                    connected  41         normal a-full a-100 10/100BaseTX
3/11                    connected  41         normal a-full a-100 10/100BaseTX
3/12                    notconnect 41         normal   auto  auto 10/100BaseTX
3/13                    connected  41         normal a-full  a-10 10/100BaseTX
3/14                    connected  41         normal a-full a-100 10/100BaseTX
3/15                    connected  41         normal a-full a-100 10/100BaseTX
3/16                    notconnect 41         normal   auto  auto 10/100BaseTX
3/17                    notconnect 41         normal   auto  auto 10/100BaseTX
3/18                    notconnect 41         normal   auto  auto 10/100BaseTX
3/19                    connected  41         normal a-full a-100 10/100BaseTX
3/20                    connected  41         normal a-full a-100 10/100BaseTX
3/21                    connected  41         normal a-full a-100 10/100BaseTX
3/22                    notconnect 41         normal   full   100 10/100BaseTX
3/23                    notconnect 41         normal   auto  auto 10/100BaseTX
3/24                    connected  41         normal a-full a-100 10/100BaseTX
3/25                    notconnect 41         normal   auto  auto 10/100BaseTX
3/26                    connected  41         normal a-full a-100 10/100BaseTX
3/27                    notconnect 41         normal   auto  auto 10/100BaseTX
3/28                    notconnect 41         normal   auto  auto 10/100BaseTX
3/29                    connected  41         normal a-half  a-10 10/100BaseTX
3/30                    connected  41         normal a-full a-100 10/100BaseTX
3/31                    connected  41         normal a-full a-100 10/100BaseTX
3/32                    notconnect 41         normal   auto  auto 10/100BaseTX
3/33                    connected  41         normal a-full a-100 10/100BaseTX
3/34                    connected  41         normal a-full a-100 10/100BaseTX
3/35                    notconnect 41         normal   auto  auto 10/100BaseTX
3/36                    connected  41         normal a-full a-100 10/100BaseTX
3/37                    notconnect 41         normal   auto  auto 10/100BaseTX
3/38                    connected  41         normal a-full a-100 10/100BaseTX
3/39                    connected  41         normal a-full a-100 10/100BaseTX
3/40                    notconnect 41         normal   auto  auto 10/100BaseTX
3/41                    notconnect 41         normal   auto  auto 10/100BaseTX
HI
Please help
That line card would need to be RMA'ed.
glen.grant
All the ports in the card are working fine....only thing is in sh module it is showing it shows faulty...
Rgds
Suresh
