Cisco CBS350 prompt Console#
Hello everyone,
CBS350 model switch, connected via CLI, starts a Marvell linux distribution, and does not load the Cisco operating system; there is the console# prompt and not the switch> prompt.
does not respond to "enable" and "configure terminal" commands.
How can I do to start the switch with Cisco OS and perform the normal configuration?
Can you help me on this?
thank you
Marcello
5 Replies 5
Does  it accept exclamation mark? it seems that it did not load the software properly and fell in some kind of rommon.  Must be some command there ir order for force the start of the IOS.
hi Flavio,
where do i find this command? is there a procedure to start os cisco?
you can use '?' in prompt and see list of supported commands. share it here
Good luck
KB
balaji.bandi
type below commands : (what you see ?)
#show run
#show verion
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-350-cli-.pdf
BB
