Cisco CCP Rejects certificate.
veeren_jain
HI All,
I was configuring a Cisco 2811 using CCP. Everything worked fine untill one day I clicked on NO when warned about the certificate being invalid/self-signed. Since then I have not been able to even discover the device. It gives me a error that the security certificate was rejected. I tried a different computer. No luck. Erased flash and config. NO luck. Would like to know how I can get the CCP to discover this device again.
I also erased the entire config and loaded on the ip addresses. Still cannot get it to work.
Thanks in advance.
Tshepo
What version of java do you have installed on your client machine?
Java 1.6.11. All other devices are discovered fine. Only one of the devices is a problem.
