Cisco CLI help
doctore11
In a nutshell, when I try to append the pipe character (|)  to a command in Packet Tracer on a 2960 switch, I get "% Invalid input detected at '^' marker." at the pipe character. For example:
show running-configuration | begin line vty
Help!
glen.grant
Sounds like a bug in packet tracer which is known to be very buggy .
Thanks guys!
I have the latest version and luckily - an actual switch 🙂
It's just much more comfortable using PT instead, oh well...
Packet tracer may not have all IOS capabilities as an actual device. I don't  use it these days, but you may check for an updated version if you have one.
Madhu
