Cisco ConfigMaker
austindaz
Level 2
Level 2
Hi;
Is Cisco Configmaker still available? I'm looking to program a 2811 with E1 and two serial interfaces.
9 Replies 9
ohassairi
Level 9
Level 9
in configmaker you can't find new routers.
i think i have an old version. if you have an ftp site i can upload it for you.
Afraid I don't have an ftp site at all. Is there any other way? Is it downloadable from the cisco website?
No files at that location - so I am assuming you are saying that cisco config maker is no longer available.
thanks
The Link is accurate, you just need to be logged in.
I only have guest login and I get the message back saying 'NOTE:
There are currently no files for this type' and then a blurb about what config maker can do. It appears that the downloadable file has been removed. Any ideas?
Wonderful - thankyou very much
larang
Community Member
Hello
Cisco ConfigMaker is still available?
I want to get this, but the link looks not working now
http://www.alliancedatacom.com/manufacturers/cisco-systems/network_management/configmaker.asp#software
How can I get this, Please help me.
