Jperf problem
UP82
Hi everybody,
i have two identical point to point connection each with 150Mbps of bandwidth.
I run JPERF on the two links with the following settings:
-TCP dual
- 10 parallel stream (to saturate the bandwidth)
On the first link,
every parallel stream get more or less the same value of bandwith (nearly 14-15....the example in the following picture show nearly 10Mbps but it's not important) and the sum is nearly 140MbpsScreenshot from 2018-04-12 09-06-39.png
On the second link the parallel streams get different value among them (the sum is still 140Mbps) and the graph is not linear as the first one:Screenshot from 2018-04-12 09-10-45.png
Is there a way to visualize only the sum of the stream instead of the single stream?
Paolo
UP82
i answer myself,....i rebooted the PC and now it works
