Cisco Configuration Professional 2.6 viewing problem
romku_korolev
I used the CP 2.3.
IE 10.
Currently, the window are displayed as in the picture.
Empty the cache Java and IE, update to ver 2.6  did not help.
I also updated the FlashPlayer to the latest version.
Help me, please.
Thanks.
Roman.
adrian.silva
Hello Roman,
open Internet Explorer 10 and press Alt key for view up menu, then click the Tools menu and Compatibility View Settings
, add IP address 127.0.0.1 for compatibility view.
It works for me.
Regards.
8 Replies 8
adrian.silva
Hello Roman,
It works for me.
Regards.
Thanks Adrian.
That worked for me
Thanks again,
Colin
thanks you sir, i had the same issue and solved.
Thanks! Adrian ... because of guys like you ... forums like CLN are really useful.
Thanks once again
Thanks. I solve it.
Gracias problema resuelto.
romku_korolev
Thank you so much. Problem solved.
brameshbabu
Thank you so much.
Ramesh
