Cisco device hardening
bwmpwnkmr
I have 500+ switches and routers in my network and want to harden those devices, is there any script or opensource tool available to do that, through which I can just specifiy the IP address and login details and hardening can be done automatically?
Pawan
Leo Laohoo
johnlloyd_13
Level 9
Level 9
hi,
you could use the 'auto secure' command.
I have to execute auto secure in each and every device which is time consuming job. I want to make it automate, so that i don't have to login on each and every device and then run the commands.
Hi  Pawan,
I am using MTPuTTY for the run script on all my network switches. One time you have to add all switches in MTPuTTY with the credential.
Hope it will work for you.
Rohit Chaudhary
