cisco DHCP
ciscoreg2
Hi, I have setup a router, it's f0/1 was connect to a AP, IP: 172.16.100.1. My DHCP server was Windows server, IP: 172.16.0.100. I have created a DHCP scope(172.16.100.100-172.16.100.200) in it. but my cellphone cannot get IP from DHCP server.
I setup below command in my router;
int f0/1
ip helper-address 172.16.1.201.
Is there anything wrong?
Terry Cheema
what is 172.16.1.201? Try changing the helper-address command to the DHCP server and test.
int f0/1
ip helper-address 172.16.0.100
-Terry
Please rate all helpful posts
sorry, it's my wrong type. my setup was just like you; it's doesn't work.
int f0/1
Hello, can u try adding the following command globally on the router.
ip dhcp smart-relay
check and see if it works.
regards
It doesn't work.
ip dhcp smart-relay seems work on one port has two ip address...
