cisco discovery tool
alessandro.dona
Level 3
Level 3
Hi guys,
any of you knows where i can download documentation regarding how cisco discovery tool works?
guruprasadr
Level 7
Level 7
HI, [Pls rate if helps]
CDP is a media and protocol independent protocol that runs on all Cisco-manufactured equipment including routers, bridges, access and communication servers, and switches.
http://www.cisco.com - Documentation Section.
Else for more Infn:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800ca66d.html
http://www.netcraftsmen.net/welcher/papers/cdp.htm
PLS Rate if Helps
Best Regards,
Guru Prasad R
Thanks guru,
but i mean discovery tool and not CDP.
Amit Singh
Alessandaro,
You will not able to find the information about CDT as it is not a free public tool available on CCO. It is used by Cisco SE's only and not even by partners. You will not get any documentation on CCO.
If you are a partner, You can open a case at partner central and request for documentation:
http://ciscopartner.esecurecare.net/cgi-bin/CiscoPartner.cfg/php/enduser/std_alp.php?p_sid=dTy1pXCi&p_lva=&p_li=&p_accessibility=0&p_redirect=&p_page=1&p_cv=&p_pv=2.3052&p_prods=3051%2C3052&p_cats=&p_hidden_prods=&prod_lvl1=3051&prod_lvl2=3052&p_sear...
Let me know if you have any specific query and I can help.
HTH,please rate if it does.
-amit singh
