CISCO E4200 VLAN
bharatchandrapenumutchu
Community Member
Hello i am trying to set up VLAN on my cisco router, where do i check for the setting for creating a VLAN on my Wireless AP. Is it possible on this model.
Bharat Chandra Penumutchu
I believe that this model do not support vlans. It has "guest" feature for the wireless only. This model is home model and in this particular group of the forums primary are discussed models which runs IOS, NX-OS, CatOS which are models usually for medium, carrier or enterprise class.
Best regards,
Alex
EDIT: I hope this link will help you more with answers about your model. Here is the link for wireless home products forum:
http://homecommunity.cisco.com/t5/Wireless-Routers/bd-p/Wireless_Routers
