CISCO FIREPOWER WITH IPS NOT ALLOWING TRAFFIC
systems100
Dear All,
Please i need help.
I migrated the running configuration on a cisco Asa firewall to FTD  using the cisco migration tool after adding the FTD device to it. i ensure there are on the same mode before the migration and infact the reason for the migration is because the Firepower device was deployed with an asa image but IPS couldn't not be enabled on the device until i change the OS on the firepower back to FTD.
Now after the migration, I can see traffic on the interfaces but but then traffic is flowing from each devices neither are the devices able to reach the internet.
I even had to change the IPS policy from balanced Security and Connectivity to trust all but its still the same.
Could it be a migration issue or is there a global policy am missing out somewhere on the FMC to reflect on the FTD, am new to FMC and FTD actually.
Please find attached screen shot for the interfaces
balaji.bandi
what is the Logs shows ? for testing try to disable Access poliocy with IPS and test.
BB
Please how do i disable the IPS on the FMC?
Check URL and Inspection on your Policies and Acces Control
here is good video walk through.
https://www.youtube.com/watch?v=8Y2Zw2wh62k
BB
