Cisco have a Fixed fiber port based Switch?
Ibrahim Bhuiyan
Hello guys,
As far as I know cisco made SFP based fiber switch. But I need fiber port based switch where I can connect fiber port directly without SFP. So cisco have any switch which has a fixed fiber port on switch but do not need SFP port seperately to connect fiber connection.
Leo Laohoo
Cisco has several models to suit your style, needs and budget:
  1. Catalyst 9300 has two models:  C9300-24S and C9300-48S
  2. Catalyst 9400 has several line cards: C9400-LC-24S & C9400-LC-48S
  3. Catalyst 9500 is an all fibre model and has a lot of choices to pick.
Leo Laohoo Those are all sfp based. But I do not need to sfp based or do not need to seperatly built in sfp module in switch. I just wanna plug&play fiber chrod in to switch port except sfp module. is it possible.
MTRJ and ST are "old school".
Nobody, including Cisco's competitors, make them anymore.
The only place to find them is through the second-hand market.
No, you will not found this type of switches in Cisco "Fiber plug and play without adding SFP/SFP+ modules". And Also I don't think it is provided by any vendor.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
