Cisco IE-3200-8P2S-E Switching Capacity
glextorment
Community Member
Hi Everyone,
May i ask that what is the switching capacity of Cisco IE-3200-8P2S-E? And also it's same for Cisco IE-3300-8P2S-E.
I couldn't see it on datasheet. May i ask why?
Thank you so much,
Mark Malone
its says its line rate in the data sheet so you should get the full 1GB per port like a DC switch no ratio on the backplane like 1:3 etc
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-ie3200-rugged-series/datasheet-c78-741758.html
Line rate for all ports and all packet sizes
3330 is line rate too
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-ie3300-rugged-series/datasheet-c78-741759.html
HI Mark
How can we measure the forwarding rate of model Cisco IE-3200-8P2S-E?
datasheet says it is line rate for all ports only, I can't find any docs showing this, or how to caculate this? please help
"datasheet says it is line rate for all ports only, I can't find any docs showing this"
Did you mean to say "any additional docs"?
"how to caculate this?"
Calculate what?  Are you asking what's line-rate?
Hello @glextorment
You can find more details on the Cisco Catalyst IE3200 and IE3300 series, including datasheets, on Cisco’s official pages:
https://www.cisco.com/c/en/us/products/switches/catalyst-ie3200-rugged-series/datasheet-listing.html
https://www.cisco.com/c/en/us/products/switches/catalyst-ie3200-rugged-series/index.html
thanks!
