Cisco IE 4010
grapevine
I have a L2 Cisco IE4010 with management ip 172.18.16.51 and default gateway 172.18.16.1. A palo alto firewall is directly connected to the switch and the Vlans are correctly configured. The connected interface on the firewall has subinterfaces with ip 10.145.16.1 and10.145.17.1 I am not able to ping 10.145.16.1 from the switch, I create a loop back on the switch with IP 10.145.16.254 and did a ping to 10.145.16.1 with source 10.145.16.254 but still doesnt work. ICMP is allowed on the firewall
Please advise how to fix this
@grapevine
 Instead of default gateway use the command
 ip route 0.0.0.0 0.0.0.0 172.18.16.1
and  make sure 172.18.16.1 can reach  10.145.16.1 and10.145.17.1
