CISCO INSTANT ACCESS SOLUTION
r.barba
Hello
I have a 6807XL Switch, and I want to migrate to Instant Access solution, which 10 Gbps Line Cards must I buy
WS-X6904-40G-2T  or  WS-X6816-10G-2T
In order to the Cisco 6800IA can joint to the 6807??
Rafael Barba
Kelvin Willacey
Level 4
Level 4
According to the Q&A it is the WS-X6904-40G-2T
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6800ia-switch/qa_c67-728684.html
Q.    What are the different components of the Instant Access solution?
A.     The Instant Access solution requires new Cisco Catalyst 6800ia Instant Access clients and Cisco Catalyst 6500 or 6800 Series Switches (Instant Access parents) with Supervisor Engine 2T and WS-X6904-40G-2T line cards. Instant Access requires Cisco Catalyst 6500 or 6800 Series Switches configured for Virtual Switching System (VSS) mode, and we recommended having a pair of switches to provide the maximum level of redundancy and load balancing. Note: In networks where a pair of Cisco Catalyst 6500/6800 is not available, a single Cisco Catalyst 6500/6800 switch may be used when configured for VSS mode.
Hello Friend
Thank you for your answer, I see that the Q&A is recomending me the WS-X6904-40G-2T , but what happend if I have the line card WS-X6816-10G-2T the Instant Access should be works??, or is there some kind of limitation with it line card (WS-X6904-40G-2T )???
Rafael Barba
As far as I know only the 6904 is supported at this time. There should be new line cards coming out soon so that might change.
