cisco IOS problem
sarenos2006
Level 4
Level 4
I have this error when I start my router
System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Copyright (c) 2003 by cisco Systems, Inc.
Bad RAM at location 0x00000000: wrote 0x00000000, read 0x00000400
Which is the problem? How can I fix it?
I suggest you remove all the modules
and check if the device boots.
If the device continues to fail to bootup, replace
the RAM.
Hope that helps
SD
adnan.zafar
Level 3
Level 3
RAM is creating problem or you can say that not compatable just change your RAM ( If 2 RAMS are placed in Router then unplugged ram 1 by 1 like unplug 1st RAM and check then place 1st RAM back and unplug 2nd RAM and then check
i m sure your problem will solve
Hope this will help you
if yes then rate this article
I have changed the RAM and the problem is fixed.
Best regards.
So is my reply helpfull to you if yes then do rate it
thanks
