05-22-2011 03:40 AM - edited 03-06-2019 05:11 PM
Hi every body
I have few questions
Solved! Go to Solution.
05-22-2011 03:56 AM
It depends on Supervisor you are using. Just try this.
Ref: http://www.cisco.com/web/go/fn
Then do <Search by Platform>
Or you may try to check this link , http://www.cisco.com/cisco/software/navigator.html?a=a&i=rpm
However,you need to have enough privilege to download software.
HTH,
Toshi
05-22-2011 04:02 AM
Hi Sarahr202,
Go to cisco website --> support --> downloads
or simply click here http://www.cisco.com/cisco/software/navigator.html
Here you can seleck the products or technology,
As per your requirements click products on the left coloum, then on the right colomn choose switches.
After clicking on the switches you can see one more coloum will appear on the right side of this coloum.
Click "LAN Switches - Access, this colum be be updated , click "Cisco Catalyst 4500 Series Switches", and then "Cisco Catalyst 4503 Switch"
Here you can choose the supervisor engine, what ever you have, let say if you have Cisco Catalyst 4000/4500 Supervisor Engine IV, click on it
then click on IOS Software.
Here you can see all the softwares available and compatible with Catalyst 4503 using Sup IV.
As per current Cisco rules , to download an IOS , you need a CCO login and smartnet of the product (you wish to download the software for that) should be associated with that CCO account.
Naveed Shahzad
05-22-2011 03:56 AM
HTH,
Toshi
05-22-2011 04:02 AM
Hi Sarahr202,
Naveed Shahzad
