Cisco IOS-XE TACACS+ priority and load balance
bakaholic39
Hello!
I am curious if I'm configuring TACACS like this
tacacs-server host 192.168.10.11
tacacs-server host 192.168.10.12
Will it be load balanced?
Will it prioritize in order?
Thanks!
M02@rt37
Hello @bakaholic39
TACACS+ configuration on most devices does not inherently support load balancing in the sense of distributing requests evenly across multiple servers. The typical behavior is failover, not load balancing. Thus, the second server acts as a backup rather than sharing the load with the first server.
Best regards
5 Replies 5
balaji.bandi
Will it prioritize in order?  - this is first one order, if that fails then second.
If you like to LB, then you need to use LoadBalancer.
BB
Reza Sharifi
Priority based. It will try .11, if not available, it will try .12
M02@rt37
Hello @bakaholic39
Best regards
johnlloyd_13
Level 9
Level 9
hi,
just be mindful, in 'newer' IOS-XE these commands are no longer supported.
these are now configured under 'aaa group server'
aaa new-model
aaa group server tacacs+ <TACACS GROUP NAME>
 server-private <TACACS HOST IP 1> key <TACACS KEY>
 server-private <TACACS HOST IP 2> key <TACACS KEY>
