Catalyst 2960 PoE-48 Switch Issues After Water Exposure
arsenzhanasbay
Hello everyone,
I have a Catalyst 2960 series PoE-48 switch that was exposed to water during a rainstorm. The switch was located in a cross-connect cabinet under an open window, and several security cameras were connected to it. Since the incident, the cameras have stopped functioning.
Current Symptoms:
  • The switch's fan is very noisy.
  • All indicators go off, and port indicators freeze.
  • Occasionally, when the fan is not noisy, the necessary indicators (like SYST) light up correctly, but this is rare.
Could anyone advise on where I should start looking to diagnose this issue? Is it possible to repair this on my own, or should I consider replacing the switch?
Thanks in advance for your help!
@arsenzhanasbay hi, if it got exposed to water there can be many circuit shorts and that can lead to component failures. specially the POE power. i suggest you to go to replacement. also this model is old and better move to recent model with support.
Good luck
KB
marce1000
                      >...The switch's fan is very noisy.
  - Usually that means that it's a fatal hardware problem as result of the water exposure.
    You may try to attach a console and have a cold start (power off/on) and check if there are any outputs on the console
    Last gasp actions could be factory reset , but I would not expect too much from that ,
 M.
Leo Laohoo
Post the complete output to the command "sh post".
