cisco IOS XE Upgrade
uni1389
Hello ,
we are using Cisco Catalyst 9300 as below in install mode and we have  completely classical routing features etc.   As we want to upgrade on Cisco Portal we have no more IOS Image  with same Bengaluru series.
I believe now we  have option to upgrade with recommended  release (cat9k_iosxe.17.15.03.SPA.bin) in bundel mode only ... Right?  Is there any valid reference for updgrade procedure.
show ver
Cisco IOS XE Software, Version 17.06.04
Cisco IOS Software [Bengaluru], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.6.4, RELEASE SOFTWARE (fc1)
Switch Ports Model SW Version SW Image Mode
* 1 24 C9300-24T 17.06.04 CAT9K_IOSXE INSTALL
7 Replies 7
balaji.bandi
INSTALL
your installed software already in ISNTALL Mode - just to clarity you like to go back to Bundle mode ?
read the release notes and check the upgrade steps :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-15/release_notes/ol-17-15-9300.html#upgrading-the-switch-software
Noes :
1. take the backup out of the box
2. give enough maintenance time to switch to reboot to get new version active.
3. collect the Logs and upgrade logs in case any issue occur when you upgrade.
4. Prepare for recovery plan in case anything go wrong
BB
Thanks. It is not necessary to go bundle mode. I believe only difference of procedure. right?
Secondly my question is that Cisco IOSXE 17.15 has only now generic release instead of Bengaluru / Dublin etc after 17.12 release. right?
Big thanks
every version IOS XE has different naming, so you do not worry about the name, Looks for stable and no bug effecting your environment before upgrade.
BB
Hello @uni1389
Can you please check this link : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-15/release_notes/ol-17-15-9300.html
You do not need to switch to bundle mode for using 17.15.xx - image supports install mode/recommendation.
Thanks !
Leo Laohoo
julian.bendix
Why not just upgrade to the recommended version in install mode? Should be fine.
uni1389
am also using stack switches C9500-24Y4C  and wants to upgrade them too.
when i am looking on show version it is not show install mode parameter.
secondly i could do ISSU upgrade of this stack and for this i need to copy desired image on both stack switch . right?
CoreStackSwitch# show version | in INSTALL
CoreStackSwitch #show issu state detail
Current ISSU Status: Enabled
Previous ISSU Operation: Successful
System Check Status
Platform ISSU Support Yes
Standby Online Yes
Autoboot Enabled Yes
SSO Mode Yes
Install Boot Yes
Valid Boot Media Yes
Operational Mode HA-REMOTE
No ISSU operation is in progress
CoreStackSwitch#SHOW REDUndancy
Redundant System Information :
Available system uptime = 24 weeks, 1 days, 4 hours, 2 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 2
Current Software state = ACTIVE
Uptime in current state = 24 weeks, 1 days, 4 hours, 2 minutes
Image Version = Cisco IOS Software [Dublin], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.12.3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2024 by Cisco Systems, Inc.
Compiled Tue 23-Jul-24 09:40 by mcpre
BOOT = bootflash:packages.conf;
CONFIG_FILE =
Fast Switchover = Enabled
Initial Garp = Enabled
Peer Processor Information :
Standby Location = slot 1
Current Software state = STANDBY HOT
CONFIG_FILE =
CoreStackSwitch#show bootvar
BOOT variable = bootflash:packages.conf;
MANUAL_BOOT variable = no
BAUD variable = 9600
ENABLE_BREAK variable does not exist
BOOTMODE variable does not exist
IPXE_TIMEOUT variable does not exist
CONFIG_FILE variable =
Standby BOOT variable = bootflash:packages.conf;
Standby MANUAL_BOOT variable = no
Standby BAUD variable = 9600
Standby ENABLE_BREAK variable does not exist
Standby BOOTMODE variable does not exist
Standby IPXE_TIMEOUT variable does not exist
Standby CONFIG_FILE variable =
CoreStackSwitch#show version
Cisco IOS XE Software, Version 17.12.03
