Cisco IOS XR netconf yang module ACL hit counts
davehouser1
System:
Build Information:
 Built By     : ingunawa
 Built On     : Mon Jun 28 01:20:45 PDT 2021
 Built Host   : iox-ucs-032
 Workspace    : /auto/iox-ucs-032-san1/prod/7.4.15.02I.DT_IMAGE/iosxrwbd/ws
 Version      : 7.4.15.02I
 Label        : 7.4.15.02I
I am trying to find a way to gather ACL hit counters from a Cisco IOS XR using yang models / netconf, then expand to grpc telemetry.
Here is what my ACL looks like, and its interface application:
#do show run ipv4 access-list testing-hit-counters
 12 deny icmp any any
#do show run interface HundredGigE 0/0/0/1.3502
Mon Oct 25 13:41:21.692 EDT
interface HundredGigE0/0/0/1.3502
 ipv4 address 10.35.2.1 255.255.255.0
 ipv6 address fdd1:10:35:2::1/64
 encapsulation dot1q 3502
 ipv4 access-group testing-hit-counters ingress
The command I am using to gather hit counters from CLI is the following, with output
#show ip access-lists ipv4 testing-hit-counters hardware ingress detail location 0/0/CPU0
on Oct 25 13:22:53.856 EDT
testing-hit-counters Details:
Sequence Number: 12
NPU ID: 0
Number of DPA Entries: 1
ACL ID: 15
ACE Action: DENY
ACE Logging: DISABLED
ABF Action: 0(ABF_NONE)
Hit Packet Count: 2
Protocol: 0x01 (Mask 0xFF)
DPA Entry: 1
Entry Index: 0
DPA Handle: 0x8F6231E8
I need to gather "Hit Packet Count:".
Troubleshooting:
  • I tried using the Cisco-IOS-XR-ipv4-acl-oper.yang yang model. Note I am using yangsuite to help analyze data / build my rpc calls. I tried pulling all the data from my access-group / sequence number, but I get no hits, here is a image of hte yangsuite model I choose. I see two intersting containers called "hits" and "police-hits"
    Here is the output of the netconf grab:
    <?xml version="1.0" ?>
    <rpc-reply message-id="urn:uuid:9dfee5cc-090a-419d-9342-5c2fbd0bd37b" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0">
      <data>
        <ipv4-acl-and-prefix-list xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-acl-oper">
          <access-list-manager>
            <accesses>
              <access>
                <access-list-name>testing-hit-counters</access-list-name>
                <access-list-sequences>
                  <access-list-sequence>
                    <sequence-number>12</sequence-number>
                    <hits>0</hits>
                    <police-hits>0</police-hits>
                  </access-list-sequence>
                </access-list-sequences>
              </access>
            </accesses>
          </access-list-manager>
        </ipv4-acl-and-prefix-list>
      </data>
    </rpc-reply>
    As you can see "hits" is 0.
  •  I believe this is an issue due to my command syntax includes "hardware" so I believe its trying to gather hardware counters, which this yang model does not support.
  • Tried messing with "Cisco-IOS-XR-fib-common-oper" but I was not successful at gathering any hardware hit counters for acl entries.
  • I noticed that I can build an ACE "counter" or "log counter", however I have no idea how I can access that information. The only way I have been able to access ACL hit counters is with the above command I shared. Is there another way to count ACL hits? Here is what my changes look like, but I cant seem to figure out where the "counter" goes to or where its logged:
    Change01:
     12 deny icmp any any counter please-countme
    Change02:
     12 deny icmp any any log counter log-counter
Any recommendations? Is there a yang file I am just not aware of that can gather the Hit Packet Count I need?
0 Replies 0
