Cisco ISR 2811 Boot problem
kamounimohamed
I have a problem when i try to boot my 2811 ISR, i tried to boot also from a usbflash i had the same error. Here is what i get when i try to boot
program load complete, entry point: 0x8000f000, size: 0x3d240
program load complete, entry point: 0x8000f000, size: 0x2a5cc10
Self decompressing the image : #################################################
########################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
0003E7          0X00474800 C2811 Mainboard
                0X000021B8 Onboard USB
                0X002C29F0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X0094A3A8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 10Mb.
Using 1 percent iomem. [10Mb/512Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T12,
RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 22-Jan-10 02:04 by prod_rel_team
Image text-base: 0x400AF970, data-base: 0x42EEB550
SDRAM ECC Error,
err addr - 0xAB07602F, err data_l 0x00000000,err data_h 0x0000000A,
rcv ecc - 0x00000000, calc ecc 0x14000000, err cnt 0xD5030000
r0  = FFFFFFFF r1  = FFFFFFFF r2  = 0        r3  = 453B0000 r4  = 0
r5  = 0        r6  = 0        r7  = 3F6006C0 r8  = 0        r9  = 462BDF5C
r10 = 0        r11 = 44D90000 r12 = 0        r13 = 110      r14 = 0
r15 = 550      r16 = 0        r17 = 550      r18 = 0        r19 = 1000001
r20 = 0        r21 = FFFFFF   r22 = 0        r23 = FF0000   r24 = 0
r25 = 110      r26 = FFFFFFFF r27 = FD0110DF r28 = FFFFFFFF r29 = FD010000
r30 = 0        r31 = 110      r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0        r49 = 45670000
r50 = 0        r51 = 1        r52 = 0        r53 = 3040A801 r54 = FFFFFFFF
r55 = A000F000 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0        r59 = 46323EE8
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0        r63 = 4033E294
sreg     = 3400C103 mdlo_hi    = 0        mdlo        = 0
mdhi_hi  = 0        mdhi       = 0        badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause      = FFFFFFFF epc_hi      = 0
epc      = 4033E2CC err_epc_hi = FFFFFFFF err_epc     = FFFFFFFF
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
=== Flushing messages () ===
: Interrupt exception, CPU signal 22, PC = 0x0
   Possible software fault. Upon reccurence,  please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback=
$0 : 00000000, AT : 00000000, v0 : 00000000, v1 : 00000000
a0 : 00000000, a1 : 00000000, a2 : 00000000, a3 : 00000000
t0 : 00000000, t1 : 00000000, t2 : 00000000, t3 : 00000000
t4 : 00000000, t5 : 00000000, t6 : 00000000, t7 : 00000000
s0 : 00000000, s1 : 00000000, s2 : 00000000, s3 : 00000000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 00000000, t9 : 00000000, k0 : 00000000, k1 : 00000000
gp : 00000000, sp : 00000000, s8 : 00000000, ra : 00000000
EPC  : 00000000, ErrorEPC : 00000000, SREG     : 00000000
MDLO : 00000000, MDHI     : 00000000, BadVaddr : 00000000
DATA_START : 0x42EEB550
Cause 00000000 (Code 0x0): Interrupt exception
*** System received a System Error ***
signal= 0x16, code= 0x0, context= 0x462a7468
PC = 0x4008d45c, Cause = 0x20, Status Reg = 0x34008002
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Initializing memory for ECC
c2811 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
I need help please ASAP thanks a lot.
Richard Burts
I would suggest that the best thing to do about this error is to open a case with Cisco TAC because they have the best tools to investigate this and to determine the exact problem.
If a case with Cisco TAC is not possible then I have a couple of suggestions which you may try:
- eject and then reseat the flash.
- remove any network cards that are in the router.
- try booting again.
- if the problem still occurs you might try opening the case and see if there is anything that you can reseat.
- if the problem still occurs you might try booting, interrup the boot to go to rommon, and try to use tftpdnld to load and run a different (perhaps smaller) image file.
Rick
Rick
Emmanuel Valdez
Level 3
Level 3
Did you try booting with other IOS image? Did the router work with this image before? There is IOS version smaller than yours.
Another problem maybe is the RAM memory, If you change the IOS version you have to check the requirements before.
Regards.
Ivan Shirshin
You have HW failure related to SDRAM memory parity errors:
    SDRAM ECC Error,
Signal 22 exception indicates a fatal hardware exception as a reason for crash.
This is either DRAM chip or chassis DRAM memory slot failure on your router.
I suggest you replace the router SDRAM first, as DRAM memory failures are most often causes for such issues. Here is the guide on how to do that:
http://www.cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/10_hw.html#wp1056378
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
