Cisco Jabber Voice call QOS issue
We have an issue reported by end user , Issue when using Cisco Jabber , The quality of the Voice is very bad but in one way .
Delay and loss of packets only in one way (statistics saw in the Cisco jabber client during a call) : delay 600ms packet loss 5%
Way Cisco Jabber Client  > to Servers TRP : quality perfect.
Way Servers TRP > to  Cisco Jabber : bad quality audio.
Please check the below configuration and let me know if we can identify any issue here ?
what are the usefull command to check the status and statistics of QOS .
Below configuration is of TRP server connected switch :
SWITCH_A1# sh int Ethernet101/1/34 | i rate
    30 seconds input rate 352 bits/sec, 0 packets/sec
    30 seconds output rate 6872 bits/sec, 12 packets/sec
    input rate 352 bps, 0 pps; output rate 6.87 Kbps, 12 pps
    300 seconds input rate 320 bits/sec, 0 packets/sec
    300 seconds output rate 6888 bits/sec, 12 packets/sec
    input rate 320 bps, 0 pps; output rate 6.89 Kbps, 12 pps
interface Ethernet101/1/34
  description DID-CONFG138_SPE-GE0/0
  switchport access vlan 699
  no snmp trap link-status
  no shutdown
SWITCH_A1# show run | i qos
policy-map type network-qos PM-NQ
  class type network-qos c-nq3
  class type network-qos c-nq2
  class type network-qos c-nq1
  class type network-qos c-nq-default
system qos
  service-policy type network-qos PM-NQ
SWITCH_A1# show policy-map interface Ethernet101/1/34 detail
Global statistics status :   enabled
Ethernet101/1/34
  Service-policy (queuing) output:   default-8q-out-policy
    SNMP Policy Index:  301993139
    Class-map (queuing):   c-out-8q-q7 (match-any)
      priority level 1
    Class-map (queuing):   c-out-8q-q6 (match-any)
      bandwidth remaining percent 0
    Class-map (queuing):   c-out-8q-q5 (match-any)
    Class-map (queuing):   c-out-8q-q4 (match-any)
    Class-map (queuing):   c-out-8q-q3 (match-any)
    Class-map (queuing):   c-out-8q-q2 (match-any)
    Class-map (queuing):   c-out-8q-q1 (match-any)
    Class-map (queuing):   c-out-8q-q-default (match-any)
      bandwidth remaining percent 100
SWITCH_A1# show queuing interface Ethernet101/1/34
slot  1
Ethernet101/1/34 queuing information:
  Input buffer allocation:
  Qos-group: ctrl
  frh: 0
  drop-type: drop
  cos: 7
  xon       xoff      buffer-size
  2560      7680      10240
  Qos-group: 0  1  2  3  (shared)
  frh: 2
  drop-type: drop
  cos: 0 1 2 3 4 5 6
  19200     24320     48640
  Queueing:
  queue    qos-group    cos            priority  bandwidth mtu
  ctrl-hi  n/a          7               PRI         0      2400
  ctrl-lo  n/a          7               PRI         0      2400
  2        0            0 1 2 3 4 5 6   WRR       100      9280
  3        1                            WRR         0      9280
  4        2                            WRR         0      9280
  5        3                            PRI         0      9280
  Queue limit: 66560 bytes
  Queue Statistics:
  queue  rx              tx              flags
  0      0               2362139          ctrl
  1      874945          0                ctrl
  2      181173060       657528193        data
  3      0               0                data
  4      0               0                data
  5      0               0                data
  Port Statistics:
  rx drop         rx mcast drop   rx error        tx drop         mux ovflow
  0               0               0               0                InActive
  Priority-flow-control enabled: no
  Flow-control status: rx 0x0, tx 0x0, rx_mask 0x0
  cos     qos-group   rx pause  tx pause  masked rx pause
  0              0    xon       xon       xon
  1              0    xon       xon       xon
  2              0    xon       xon       xon
  3              0    xon       xon       xon
  4              0    xon       xon       xon
  5              0    xon       xon       xon
  6              0    xon       xon       xon
  7            n/a    xon       xon       xon
  DSCP to Queue mapping on FEX
DSCP to Queue map disabled
FEX TCAM programmed successfully
0 Replies 0
