Cisco Basic nat not working
Ss73293
See attached image.
I have two routers at L3 and the first one is doing NAT to and from internet. W1 is the WAN router (from ISP, which is also doing a NAT and giving dhcp IP to the R1) I have configured basic nat and static routing on two routers, R1 and R2. The problem is:
from R1, I can ping internet gateway 192.168.1.1
From R2, I can ping R1's 192.168.1.2 but not 192.168.1.1
From PC, I can not ping / reach outside.
Can someone help if I am missing something?
Config:
R1:
# Interface gi1/0/1
# ip address dhcp
# ip nat outside
# Interface gi1/0/15
# ip address 10.10.10.1/24
# ip nat inside
# ip route add 10.10.0.0/16 10.10.10.1
# ip nat inside source list 101 interface gi 1/0/1 overload
# access-list 101 permit ip any any
R2:
# ip address 10.10.10.2/24
# Interface gi1/0/1
# ip address 10.10.11.2/24
PC:
# ip address 10.10.11.3/24
Default Gateway 10.10.11.2
6 Replies 6
Cristian Matei
   1. Sometimes, "permit ip any any" in the NAT config creates some problems; replace that statement with "permit ip 10.10.0.0 0.0.255.255 any".
  2. Make sure you actually get an IP address from the DHCP server.
  3. Who you ping from the PC to the ISP router, look in the NAT translation table, do you see any translations? "show ip nat translations".
Cristian Matei.
Thankyou Cristian.
Answers below:
a) I have made the change to 'permit ip 10.10.0.0 0.0.255.255 any'
b) I get the IP address 192.168.1.2 form ISP router / DHCP. From R1, I can ping the gateway (192.168.1.1) ,  google.com and others.
c) Now, from the PC and from R2, I can ping 192.168.1.2 (last hop to internet router), but no response from PC or R2 when I ping 192.168.1.1.
So something is wrong with the NAT.
I don't see any entry in the NAT table on R1.
R1#show ip nat translations
R1#
R1#show ip nat stat
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
GigabitEthernet1/0/1
Inside interfaces:
GigabitEthernet1/0/15
Hits: 12 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 2
Dynamic mappings:
-- Inside Source
[Id: 4] access-list 105 interface GigabitEthernet1/0/1 refcount 0
R1#show ip route
Default gateway is 192.168.1.1
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
On R2:
R2#show ip route
Default gateway is 10.10.10.1
Also this is a Cisco Catalyst 3560-CX. Is NAT supported in this?
No, that switch does not support NAT. To do NAT, you need a router.
   Based on the output, there is no "routing" configured on your routers. Can you enable "ip routing" on all routers and test it again?
R1#show ip route
R2#show ip route
Cristian Matei.
Hello
Looks like you need to double nat unless that is you are able to change the nat on the isp router, Try appending the following configuration,
R1
no ip route 10.10.0.0 255.255.0.0 10.10.10.1
ip route 10.10.11.0 255.255.255.0 10.10.10.2
ip route 0.0.0.0 0.0.0.0 gig1/0/1 dhcp
int gig1/0/1
ip nat outside
int gig1/0/15
ip nat inside
exit
no access-list 101
access-list 101 permit ip 10.10.10.0.0.0.255 any
access-list 101 permit ip 10.10.11.0.0.0.255 any
Kind Regards
Paul
