Cisco L3 WS C3550 24Power SMI do not boot to switch prompt via console connected via tera term or putty
arindomsil
Hi All...
My name is Arindom and from IN Kolkata.
I have found that my Cisco L3 WS C3550 24Power SMI switch has corrupted flash.
As it has no other option I tried to boot it via console but failed deliberately.
Upon powered on - the system light (led) blinks in green for few seconds after that port 1 led goes off with remaining led ports green steady and the system light (led) becomes steady green.
I never get any dialogue or switch connectivity via console.
Tried to put this switch on for several hours and then turned it off.
Once happens I get the switch prompt back and found it is being forced reload.
the image file loaded in there is c3550-ipbase-mz.122-44.SE3,bin
I found the image file name shown is  c3550-ipbase-mz.122-44.SE#,bin
I then tried formatting flash.
while I saw several flash blocks are damaged or corrupt and dialogue comes about fixing.
But immediately after that it again goes unresponsive.
I switched it off and powered on.
still now I am unable to get back the switch prompt via tera term or putty.
Please suggest on this.
I think my flash chip is gone corrupt and need to replace the chip will only solve.
Please suggest your valuable opinion in this regards
Arindom
Kolkata
IN
marce1000
 Ref : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-2_4_e/configurationguide/b_1524e_consolidated_3750x_3560x_cg/b_1524e_consolidated_3750x_3560x_cg_chapter_0111011.html?bookSearch=true#task_7591ACFAB45342B29F44...
                        Check if you still might be able to recover the flash : start from step 3
 M.
balaji.bandi
Setup a TFTP software in the network and copy the image into TFTP  ( make sure you check the image you downloaded correct0 check with md5 checksum to verify also.
Try below steps : ( make sure you change the IP and IOS verion you looking to load in to device - change accordingly)
switch: IP_ADDRESS=192.168.1.1
switch: IP_SUBNET_MASK=255.255.255.0
switch: TFTP_SERVER=192.168.1.2
switch: TFTP_FILE=c3550-ipservicesk9-mz.122-35.SE5.bin
switch: DEFAULT_GATEWAY=192.168.1.1
switch: set
BOOT=tftp://192.168.1.2/c3550-ipservicesk9-mz.122-35.SE5.bin
switch: boot tftp://192.168.1.2/c3550-ipservicesk9-mz.122-35.SE5.bin
Once it boot switch #
Format the flash and copy the image from TFTP to Switch - setup the boot variable as per the below document and wr and test.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3550-series-switches/41541-190.html#concept2
BB
marce1000
 M.
arindomsil
1st of all, I like to give thanks for this early and prompt help.
I have found that the image originally I loaded c3550-ipbase-mz.122-44.SE3.bin was corrupted as after transferring it via tftp method - it says bad zip and invalid zip method.
I then changed the file ios with another ip base image with different train ID like SE6.bin....it boots and extracted successfully.
But now I have stuck in another problem. I have attached the exact notification for your ready reference and guide me further sir.
Arindom Sil
IN
Kolkata
 - If you tried another ip base image, then verify it (too) using md5 checksum verification before loading into the switch.
 M.
