Cisco LAN router
luthierone
Could anyone recommend a router for me? I need the samllest router possible (1u) that has or has support for 3 fast ethernet interfaces and support for vlan routing.
thanks!
Thanks!
If your looking for pure LAN routing (only Fast Ethernet) then look into a 3550 EMI if you can find one for sale or look at 3560's. You should be able to get them in 24 ports and they will do standard IP IOS which now included EIRGP Stub Routing but in your case it sounds like you would want Advanced IP IOS which will include full LAN routing as well as options such as multi-cast routing.
Good Luck.
