Cisco Login using Encrypted Password
Mokhalil82
Level 7
Level 7
I want to find out if I can login to a cisco switch (Nexus 7000) using the encrypted password.
The reason? well my nexus 7000 has a memory issue and requires a reboot to fix, so currently is not saving configs. The local account on the running config has a different password that the local account on the startup config.
After the reboot it will revert me to the startup config so I am wondering if I could login using the encrypted Type 5 password in the backed up startup config.
Philip D'Ath
Meraki Community All-Star
Not to the best of my knowledge, no.
Bit of a long shot, but use Google Chrome (fastest) and try my type 5 password breaker.
http://www.ifm.net.nz/cookbooks/cisco-ios-enable-secret-password-cracker.html
Use it on a machine you can leave running for several days.  The more CPU cores the better.
