04-24-2016
		02:56 AM
 - last edited on
		03-25-2019
		04:38 PM
 by
			ciscomoderator
When reading documentation about how to configure port-channel interfaces with the role of virtual switch link among two VSS enabled chassis, I couldn't find any reference about specifically configure the VSL port-channels as "switchport" o "no switchport". According to what I understand configuring these two port channels as "no switchport" is the right approach. However, I would be grateful if somebody could confirm it. Would there be any impact if they were configured as "switchports"? I tested this last "switchport" config in the lab and everything seemed to work right, too. I mean the ordinary config:
interface port-channel 1
switch virtual link 1
no shutdown
vs this alternate one with the port-channel configured as a "switchport" that it seems to work too
switchport
no shutdown
Thanks in advance
Kind regards
Octavio
Solved! Go to Solution.
04-24-2016 08:49 AM
What platform are you using? It appears there are 2 versions of this. The 4500x works as switch port and the 6800 works only as no switch port.
BTW, it used to be all switch ports for all platforms.
04-24-2016 10:14 AM
Yes, if its switch port than it needs to be trunked.
Your config should look like this (per interface). Most of these commands are added by default when you convert the interface to VSL I am not sure about "switchport mode trunk" if this command is not added by default, you can add it to the Portchannel and the physical interfaces should inherit that.
interface TenGigabitEthernetx/x/x
 description VSL Link Member
 no lldp transmit
 no lldp receive
 no cdp enable
 channel-group 16 mode on
 service-policy output VSL-Queuing-Policy
04-24-2016 08:49 AM
04-24-2016 09:41 AM
Thank's a lot, Reza. That's the explanación. It's a 4500X. If configured as switchports, do I hace to worry about the allowed VLANS on the VSL port-channels? Do I have to allow every configured VLAN on the switch?
Thanks in advance
Octavio
04-24-2016 10:14 AM
 no lldp transmit
 no lldp receive
 no cdp enable
04-24-2016 01:36 PM
Thank you, Reza. I've just tested it and it works fine. Every defined VLAN is sent over the trunk of the VSL port channel.
Thanks a lot for your help
Octavio
04-24-2016 03:32 PM
Glad to help and thanks for the rating!
Good Luck
Reza
