Cisco Macsec - Interface protocol down
osw200051
Level 3
Level 3
Hi Exprt,
I am deploying cisco macsec by using two cisco C9300 in two sites. And the inter-connection is using MetroEthernet.
But found that after deployed macsec, physical port status is up, but protocal is down.
After debug the mka policy, found that "No live peers present, so need to send a MKPDU with just a Live/Potential Peers Parameter Set."
Did anyone have same experience and can share the resolution to me?
balaji.bandi
We do run some MACsec between Cat 9500 part of the testing never seen this error :  ( what IOX SE code running, you confirmed before enable MACsec Link working as expected right ?)
Look at some troubleshoot guide :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216849-troubleshoot-macsec-on-catalyst-9000.html
BB
Mark Elsen
 - Check if this bug report could apply :
               https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf86295
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
