Cisco N5k enable 'feature fex'
johnlloyd_13
Level 9
Level 9
hi,
i'll be installing N2K copper modules and patch 10G fiber uplinks to a pair of parent N5K.
my question is, is it required to enable 'feature fex' just to confirm the N2K has connectivity/discovered by parent N5K?
or would it show as 'discovered' by the parent N5K even without applying 'feature fex'.
i just need to verify it's being detected/discovered by the parent N5K after installed, powered on and patched. there's no further provisioning yet.
Hi John,
one last question, can i just patch a single fiber uplink to a single parent N5K and the N2K would still be able to download its image?
That should not be an issue. As soon as the FEX comes online, it will download the OS from the parent switch.
8 Replies 8
Mark Elsen
           >...or would it show as 'discovered' by the parent N5K even without applying 'feature fex'.
 I would simply examine the logs ( show logging)  when connecting and look for info's concerning this
 M.
Reza Sharifi
Yes, the command is feature-set fex.
Once enabled and configured, you can verify with "show fex x" and/or "show fex x details"
hi reza,
thanks! i believe the newer NX-OS command is 'feature fex'
does the 'fex associate' and 'vpc' number needs to be the same or not?
interface Eth1/30
description *** FEX100 - CORE RACK ***
switchport mode fex-fabric
fex associate 100     <<< WE WANT PORT NUMBERING STARTS WITH 100, Eth100/1/1
channel-group 111   <<< PORT-CHANNEL 100 IS ALREADY TAKEN
interface port-channel111
fex associate 100
vpc 111    <<< VPC 100 IS ALREADY TAKEN
Hi John,
No, you can use different numbers, but for consistency and ease of management, I always use the same number for VPC, FEX, and PO where possible.
hi reza,
thanks! it's good to have consistent/same numbers but like i said port-channel 100 and VPC 100 were already taken so i need to use another number.
hi reza,
i want to upgrade the N2K while waiting for additional 10G SFP and MM fiber to arrive.
Hi John,
balaji.bandi
Make sure you have right Nexus code to support FEX with compatable :
below config will help you :
install feature-set fex
feature-set fex
!Fex Config
fex 100
pinning max-links 1
!Fex provisioning
slot 100
provision model N2K-C2248TP-E-1GE
!Interface config
interface Ethernet1/10
fex associate 100
channel-group 100
!port channel associated with FEX
interface port-channel00
fex associate 100
vpc 100
BB
