Cisco NAT question
sslack031
Hi All,
I've configured NAT on a Cisco 1921 router. I've configured port 25 to be forwarded to a mail server however, when I connect a site using a site to site IPsec vpn everything works besides the ports that I have NAT'd in.
ip nat pool WIGAN 22.22.22.154 22.22.22.158 netmask 255.255.255.248
ip nat inside source list 98 pool WIGAN overload
ip nat inside source list 110 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 192.168.1.245 443 22.22.22.156 443 extendable
ip nat inside source static tcp 192.168.1.241 25 22.22.22.157 25 extendable
ip nat inside source static tcp 192.168.1.241 80 22.22.22.157 80 extendable
ip nat inside source static tcp 192.168.1.241 143 22.22.22.157 143 extendable
ip nat inside source static tcp 192.168.1.241 443 22.22.22.157 443 extendable
ip nat inside source static tcp 192.168.1.241 993 22.22.22.157 993 extendable
ip nat inside source static tcp 192.168.1.247 443 22.22.22.158 443 extendable
ip nat inside source static tcp 192.168.1.247 3389 22.22.22.158 3389 extendable
access-list 110 deny   ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 110 deny   ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
can anyone shed any light on this?
Collin Clark
Check this link, specifically the R3 configuration.
http://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/14144-static.html
Collin Clark
Hi Colin,
Thanks for the reply,
So to confirm if i amend the following line:
to
ip nat inside source static tcp 192.168.1.241 25 22.22.22.157 25 route-map nonat
and then add a route-map in to include all the ip addresses i don't want nat to touch.
i.e
access-list 150 deny   ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 150 deny   ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 150 permit ip 192.168.1.0 0.0.0.255 any
route-map nonat permit 10
 match ip address 150
Would that work?
Ryan Curry
Hi sslack, I'm a little confused by the situation.  Are you NATing across the VPN or are you NATing on the outside interface coming in?  It sounds like you're doing a Site-to-Site with a NAT in place?  If it's a site-to-site, what does the crypto map look like?
