Guidance on networking home router to 3550 switch
R7drig0
I've connected a netgear 3400 wireless router to a cisco 3550 switch.  The router is coming off the DSL modem.  So far all connected devices including the router are in vlan 1, (printer, pc's etc.).  I have configured the switch with a management ip address it actually configured itself when I plugged in the router and too on the gateway address.  All has been working but I wondered if I should put the router on it's own vlan (vlan 4 or whatever).  Is this the proper way to configure a home network using this equipment?
Dan Lukes
Note from the forum description:
Note: If your questions pertain to specific Cisco technology or solution, please post them in the proper community by leveraging the Community Directory so that folks who have expertise within those areas can engage and collaborate to it.
sarakhan25217
Open a user profile page (e.g. https://supportforums.cisco.com/users/<username>). Open the HTML source of page.
___________________________
sara
Ryan Curry
The issue you're going to run into is that if the gateway is on VLAN 4 and your devices are on VLAN 1, you'll need to route between those two VLANs (either via a route on the switch or another routing device/interface).  I would suggest you maintain everything on VLAN 1 and maybe bring up a test network on VLAN 4 to get comfortable with layout.
