09-30-2017 07:46 AM - edited 03-08-2019 12:13 PM
Hi All,
Not sure if I am missing something, but when I use Cisco network assistant to have a look at port settings for one of my switches (Trying to set ESXi port speed to auto which is failing, so investigating negotiation settings on the switch), it seems the port settings window when right clicking on the port and viewing port settings, does not match what is shown in the global port settings page:
Top pane is global port settings, and lower pane is from when I right click on the port from the front panel window.
As you can see, the lower pane says the speed is 10, but global port settings says auto. Other ports don't seem to have the mismatch, so I am now unsure which of the two windows is giving me correct information.
Below is output from show interface for problematic port and non problematic port:
CB-SW-02#show interface GigabitEthernet2/8
GigabitEthernet2/8 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0024.1440.9ef7 (bia 0024.1440.9e f7)
Description: FLX-ESXi-02-MGMT
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is on, output flow-control is on
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 4213818
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 145000 bits/sec, 46 packets/sec
5 minute output rate 738000 bits/sec, 173 packets/sec
356200043 packets input, 225625467309 bytes, 0 no buffer
Received 8512064 broadcasts (3020115 multicasts)
8817025238 packets output, 2523569590042 bytes, 0 underruns
0 lost carrier, 0 no carrier
CB-SW-02#show interface GigabitEthernet2/9
GigabitEthernet2/9 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is 0024.1440.9ef8 (bia 0024.1440.9ef8)
Description: *** Server Access Port ***
Auto-duplex, Auto-speed, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 160940
9217495 packets input, 2493949841 bytes, 0 no buffer
Received 39883 broadcasts (38 multicasts)
8059464519 packets output, 2073197862973 bytes, 0 underruns
0 output buffer failures, 0 output buffers swapped outThis confuses me even more, as it doesn't show auto, or 10, it shows full duplex 1000Mb/s.
Is the gui wrong, or am I misinterpreting what I am reading?
Cheers
Eds
09-30-2017 10:48 AM
the reading is probably related to what is connected on the other end. If you disconnect the device, do you get the correct value (auto) ?
10-01-2017 02:08 AM
11-10-2017 01:41 AM
Well it's a bit late, but the issue here seems to lie with vmware.
When I tried to change to auto negotiate for one NIC on one host via vcenter, it would fail. If I then did the same directly via the management interface for the host, it would complete successfully.
The modify port settings box still shows a speed of 10, but I believe this erroneous as vmware does now show auto negotiated at 1000Mbs.
Eds
